Apill
Oct 12, 2018 1:27 AM UTC
While integrating SD card with Stm32 in SDIO, FATFS. How can i make the text enter in new line? and also how can i save an integer not characther, How can that be feasible?
I am referring to FATFS library
1.I tried to use \n and \t it didnt work. i wanted to make text appear in a new line.
2. in the memory card i wanted to store a vairable integer, How can i do that? As of now i could able to save only character.
In FATFS is there any other way i can save data apart from .txt file?
    Tesla DeLoreanBest answer
    Oct 12, 2018 3:08 AM UTC
    How do you normally do file IO with STDIO functions? FATFS is pretty similar.
    Use \r\n
    int x = 1234;
    f_write(&fil, &x, sizeof(x), &byteswritten); // pretty inefficient
    f_write() writes binary data, it doesn't know you're using a text file.
    Name files how you want.
    Write the content you want.
    Use \r\n
    int x = 1234;
    Apill
    ApillAuthor
    Oct 24, 2018 9:22 PM UTC
    @Community member​ , i have exactly used the above mentioned lines. I have got the output as below;
     Ò
    I tried to output to .txt file and .binary file. the same issue. Any suggestions please
    Oct 24, 2018 10:21 PM UTC
    File content does not depend on the naming.
    Files are a collection of bytes.
    Data stored in a native binary form does not appear in human readable ASCII.
    Use a file viewer or hex editor to review the content of a file.
    Apill
    ApillAuthor
    Oct 25, 2018 1:03 PM UTC
    if i write the following:
    char myData [] = " hello ashok\0";
    f_write(&myFILE, myData, sizeof(myData), &testByte);
    The output of the above is:
    hello ashok.
    How can it differ from characther to numbers
    Oct 25, 2018 3:46 PM UTC
    Certainly indicative of a problem at the SDIO or FATFS levels.
