Kapil Sharma
Feb 13, 2018 9:40 AM UTC
While Debugging STM32F303RC
Posted on February 13, 2018 at 10:40
  1. #@Hi everyone,
I am Kapil Sharma,
I have custom Board.When i am trying to debug code running  successfully and the Command log of Keil shows this..
* JLink Info: Found SW-DP with ID 0x2BA01477
* JLink Info: Scanning AP map to find all available APs
* JLink Info: AP[1]: Stopped AP scan as end of AP map has been reached
* JLink Info: AP[0]: AHB-AP (IDR: 0x24770011)
* JLink Info: Iterating through AP map to find AHB-AP to use
* JLink Info: AP[0]: Core found
* JLink Info: AP[0]: AHB-AP ROM base: 0xE00FF000
* JLink Info: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
* JLink Info: Found Cortex-M4 r0p1, Little endian.
* JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
* JLink Info: CoreSight components:
* JLink Info: ROMTbl[0] @ E00FF000
* JLink Info: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
* JLink Info: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
* JLink Info: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
* JLink Info: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
* JLink Info: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
* JLink Info: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
ROMTableAddr = 0xE00FF000
* JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
* JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ.
can you provide me any solution for my problem?
    AvaTar
    Senior III
    Feb 13, 2018 10:00 AM UTC
    Posted on February 13, 2018 at 11:00
    What problem ?
    I can't see any error message in the log.
    And the question is 'assumed answered' anyway ...
    Kapil Sharma
    Feb 13, 2018 10:05 AM UTC
    Posted on February 13, 2018 at 11:05
    While i am debugging the code the comment log shows below
    AvaTar
    Senior III
    Feb 13, 2018 12:21 PM UTC
    Posted on February 13, 2018 at 12:21
    And how do you come to think of this as an error ?
    The debug adapter resets the core in order to invoke the reset vector/handler, and start the user application.
