Alex Golubev
Where can I get an example of starting an ADC on a stm32h743 microcontroller using DMA?
  • December 19, 2020
  • 652 views
Hi.
I need an example on CMSIS of running an ADC using DMA. Where can I get it?
Use a working HAL example to figure out what register settings you need:
https://github.com/STMicroelectronics/STM32CubeH7/tree/master/Projects/NUCLEO-H743ZI/Examples/ADC/ADC_DMA_Transfer
There's probably an LL example somewhere which may be easier to translate.
Imen GH
Hello @Alex Golubev
There is no example on CMSIS but the automatically generated code from CubeMX with LL drivers can help you.
Also, please have a look in the cube example.
Imen
