JKoro.1
When sending duty cylcle values to PWM output with DMA some values get skipped
  • August 19, 2020
  • 720 views
When I try to change the duty cycle with DMA I notice that some values are not correct some of the time. I know that I am sinding the right values, but the PWM signal is not correct. Is this a problem with the preload registers and how can I set them in a better way so that this does not happen?
waclawek.jan
Read out and post the TIM, DMAMUX and DMA registers content.
JKoro.1
JKoro.1Author
Well, I just switched the timer generating the PWM signal from TIM2 to TIM1 and it seems to work. Thanks for being interested.
