infoinfo986
When Peripheral Library for STM32F2xx family?
  • April 20, 2011
  • 12 replies
  • 2518 views
Posted on April 20, 2011 at 23:12
#lmgtfy:-firmware-library #lmgtfy:-firmware-library
    luangzc
    Posted on May 17, 2011 at 14:32
    Andrew Neil
    With a little thought, it's not really that hard to find:
    https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/DispForm.aspx?ID=16297
    May 17, 2011
    Frankly you might want to try the most current download from Keil (MDK 4.14+) or a support package from Rowley.
    http://www.keil.com/dd/docs/arm/st/stm32f2xx/stm32f2xx.h
    drzile86
    I think, but I'm not sure that, you can use std peripheral lib for STM32F1xx for standard peripherals like USB, I2C, USART, SPI.... Only different between STM32F1xx and STM32F2xx is that STM32F2xx are faster, and hve camera interface.
    Regards,
    Dragan
    infoinfo986
    infoinfo986
    infoinfo986
    May 17, 2011
    This is still not a solution but workaround. Does anybody ( including ST moderators) know where can I find peripheral library for STM32F2xx family?
    If you are using this part, or planning too, you should call/email your local ST distributor/rep/FAE, and light a fire under them.
    It really should be on the support website by now, but it's such an awful mess to locate things quickly.
    Andrew Neil
    Finally, it's arrived:
    /ce74caf8
    ariyo48
    Posted on March 26, 2012 at 06:01
    I have same problem with him. All link is dead. Where I can find it?and where I can find .lib file for stm32f2xx?
