Nsg1987
What is the lower frequency signal generated from HR Timer?
  • May 23, 2023
  • 3 replies
  • 935 views
I am able to generate PWM frequency of 640 Hz using HR Timer. Now I want to generate the same with 100 Hz. I tried to manage clock prescaler but found no success.
Hi @Nsg1987​
Can you precise STM32 that you're using ?
Diane
Nsg1987
Nsg1987Author
Hi @Diane POMABIA​
I am using STM32G474VBTx.
Regards,
Nikhil
Hi @Nsg1987​
You can refer to AN4539 that will give you more detail about HR Timer feature :
https://www.st.com/resource/en/application_note/an4539-hrtim-cookbook-stmicroelectronics.pdf
DianeP
