What does the internal temperature sensor measure?
We are using an STMF4 and STMF3 in our product and are trying to see if we need to switch to the industrial variant for the extended temperature range.? Is the internal temperature sensor measuring the Die temperature, and if so is that essentially reading the junction temperature?
Thank you,
-Patrick
