Jansunil
What does the HAL_SAI_Receive() function take in as the parameter- 'Size'?
I am trying to use the HAL_SAI_Receive() function from the STMF767xx SAI drivers to receive some data from a device and I would like to know what does the 'Size' parameter actually represent.
My scenario is as follows:
1.) The SAI operates in slave mode
2.) data size in a slot is 8 bits
3.) FS active length (on time of the FS pulse) is 32 bits
4.) Each 4 slots per FS pulse
In the above scenario, would the 'Size' parameter be ? would it be equal to :
(a.)The data size per slot? or would it be (or)
(b.)number of slots*data size per slot? (or)
(c.) something else?
TDKBest answer
November 25, 2021
It is the number of data words to receive in units of the datasize you have defined.
In this case, if you want to receive 32 bits and your data size is 8 bits, it should be 4.
TDKBest answer
November 25, 2021
Jansunil
JansunilAuthor
This is clear. Thank you @TDK​
