adrian4
WFI problem
  • June 25, 2009
  • 11 replies
  • 5039 views
Posted on June 25, 2009 at 20:54
WFI problem
    adrian4
    adrian4Author
    Posted on May 17, 2011 at 13:13
    Spot on Andreas.
    NVIC_GenerateSystemReset() did the trick.
    It is now functioning as I intended.
    Thanks very much.
    Can you tell me where this function is documented with this level of detail?
    The ST FWLib document just tells you that the function exists and a one line example of its use.
    Cheers
    Adrian
