Wanted To confirm The IDE for the development
Hi we're using STM32L412RB controller for our development wanted to know what are preferable IDE that can be used for the software development for the purchased controller.
STTwo-32
STTwo-32Best answer
Hi again @Adithya_Jayaram
I personally recommend the STM32CubeIDE wish is open-source and will meet perfectly your needs. If you are looking for other IDE, I suggest you use Keil and IAR for your project (both are under license).
Best Regards.
STTwo-32
STTwo-32
Hello @Adithya_Jayaram and welcome to the ST Community.
I advise you to use the last versions of STM32CubeIDE (all-in-one multi-OS development free tool) and CubeMX
(a graphical tool that allows a very easy configuration of STM32 microcontrollers).
Best Regards.
STTwo-32
Any other IDE's? other than STM, please give me couple of options so I could check if i can get the license for the same(as it's a corporate project have to get the license for the same so need options ).
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
Hi , we're suggested to use eclipse, just wanted to know is it compatible with STM32L412RBT6P.
Southbranch
Senior
December 1, 2023
Good questiion,
I am using CubeIDE but I plan to test out Viusal Studio Code with the add-in for STM32. Has anyone tested this, pros and cons? What about pin-configuration possibilites?
