Sandeep singh
want to send 16 bit data using by spi using cubemx
  • May 25, 2018
  • 1 reply
  • 684 views
Posted on May 25, 2018 at 08:56
I m  totally new to stm32 , I am using stm32f0rb nucleo board ,now I want to connect ic using SPI and send 16 bit data to ic can anyone guid in proper way , I want to generate code using stmcubemx.
    Posted on May 25, 2018 at 14:11
    Hello
    sandy.sandy
    Have a look to the
    in section SPI (from page 187) it can help you onhow to configure SPI using STM32CubeMX .
    You may refer to theSPI
    example within STM32CubeF0 v1.9.0 firmware package:
    STM32Cube_FW_F0_V1.9.0\Projects\STM32F070RB-Nucleo\Examples\SPI
    The
    http://www.st.com/content/ccc/resource/technical/document/user_manual/2f/77/25/0f/5c/38/48/80/DM00122pdf/files/DM00122pdf/jcr:content/translations/en.DM00122pdf
    U
    ser manual Description of STM32F0 HAL and low-layer drivers, will helps youto understand the purpose of HAL functions and toknow how the structures are defined.
    Best Regards,
    Imen
