cnc_designer
Jan 9, 2014 1:46 AM UTC
Very very easy to write C programs in to STM32F4 Discovery with ZIOS
Posted on January 09, 2014 at 02:46
I wrote a library for the STM32F4 Discovery kit. The name of this library is ZIOS.
ZIOS includes low level functions. You don't need to MCU registers access for your application programs.
Also I wrote simple demo programs via Keil. when you examine you will realise that it's very easy.
Also i made short video about the functions of ZIOS.
http://www.youtube.com/watch?v=AnEpH6E2fiQ&feature=youtu.be
ZIOS functions use this pins.
http://www.cncdesigner.com/wordpress/wp-content/uploads/ZIOS.jpg
Complete project directory.
http://www.cncdesigner.com/wordpress/wp-content/uploads/ZIOS_Demo.rar
LCD Connection diagram.
http://www.cncdesigner.com/wordpress/wp-content/uploads/LCD.jpg
#stm32f4-discovery #i2c #zios #stm32f407
dsevc
Jan 9, 2014 9:32 AM UTC
Posted on January 09, 2014 at 10:32
Hi. I see your web page . Is not in English language.. but see photo .. first photo in your web page is CNC - USB controller (3-axis) .. ??? is possible ZIOS use in STM32F429i DISCO kit??
best regards
cnc_designer
Jan 9, 2014 9:39 AM UTC
Posted on January 09, 2014 at 10:39
Yes this card 2.5  axis cnc controller and stepper motor driver.
I don't now is ZIOS work with STM32F429i.
dsevc
Jan 9, 2014 11:58 AM UTC
Posted on January 09, 2014 at 12:58
hi. 2.5 axes only .. third axes not use stepper motor?? can you provide more information?? you make this project self or order ??  I have idea to use my STM32F429i DISCO to make CNC controller .. load G-code file from SD card or external Flash disk ..and mill by 3-axes .. of course then is possible to make from this 3D printer also..
what IDE you use .. I start with CooCox.. and try uClinux .. but I don't know compile source in my PC , I try run live Ubuntu STL 12 .. and try start all script .. but not work..
best regards.
cnc_designer
Jan 9, 2014 2:34 PM UTC
Posted on January 09, 2014 at 15:34
Third axes drive voicecoil. This is my old project. Controller/driver board connecte  to PC by USB interface. Now I change to SD card.
dsevc
Jan 9, 2014 2:57 PM UTC
Posted on January 09, 2014 at 15:57
is possible to write more about your project?? to email pls .. sevc @ post.sk
thanks.
cnc_designer
Jan 10, 2014 1:59 PM UTC
Posted on January 10, 2014 at 14:59
Did you try the ZIOS for STM32F429i? Is it work?
Jan 10, 2014 3:35 PM UTC
Posted on January 10, 2014 at 16:35
Doubtful, the pins are totally different on the STM32F429I-DISCO, and most everything is consumed by LCD and SDRAM pins.
The SDIO interface is broken to just one pin/bit, but then again you're using SPI mode rather than 4-bit SDIO in your current project.
cnc_designer
Jan 18, 2014 2:05 PM UTC
Posted on January 18, 2014 at 15:05
STM32F407 I2C too simple by ZIOS V1.03
Example: I2C register access for TCM8240MD camera.
#include ''Zystem.h''
short T;
void MiliSecond()
    if(T) T--;
int main()
char RxData;
//  TCM8240MD I2C example
    pinmod('D',1,output);    // GPIOD02 is a output for the TCM8240MD Reset pin
    pinclr('D',1);           // TCM8240MD Reset line is low
    T=100; while(T);         // wait 100ms
    pinset('D',1);           // TCM8240MD Reset line is high
    T=10; while(T);          // wait 10ms
    I2Cinit(400000);         // I2C clock frequency is 400 Khz
//  Lets read 0x04 location of TCM8240MD
    I2Cstart();              // Start Condition
    I2Ccmd(0x3D,0);          // TCM8240MD Adr=0x3D, (R/W bit=0, write means)
    I2Cwrite(0x04);          // TCM8240MD register address is 0x04
    I2Ccmd(0x3D,1);          // TCM8240MD Adr=0x3D, (R/W bit=0, read means)
    RxData=I2CreadNack();    // Read [0x04] register (No ACK)
    I2Cstop();               // Stop condition
//  Lets write 0x0B in to 0x04 location of TCM8240MD
    I2Cwrite(0x04);          // Register address is 0x04
    I2Cwrite(0x0B);          // Register data is 0x0B
    while(1);
