matic
Apr 1, 2016 5:06 AM UTC
Vbat circuitry
Posted on April 01, 2016 at 07:06
Hi.
We would like to store some data in a backup registers using supercap as an additional power supply.
Do you have maybe any recommendation for the circuitry around the supercap? Or maybe an example of it? It should be quite robust.
Thanks a lot
    Amel NASRI
    Apr 1, 2016 11:05 AM UTC
    Posted on April 01, 2016 at 13:05
    hi odib.matic,
    Depending on used device, you should find an application note (
    Getting started with xxxxxxxxxxx MCU hardware development)
    providing recommendations on how to design your PCB.
    In the case of STM32F407 for example, it is the
    http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00115714.pdf
    : Getting started with STM32F4xxxx MCU hardware development.
    -Mayla-
