simon2
Using ST-Link with Keil
  • January 14, 2010
  • 5 replies
  • 1589 views
Posted on January 14, 2010 at 09:00
    simon2
    simon2Author
    Posted on May 17, 2011 at 13:38
    I have been using the ULink - me for debugging and programming but due to a couple of failures, decided to look for an alternative.
    Been trying to get the ST-Link to work with Keil u-vision 4, after connecting the device the red com light came on and all seemed to be well. changed the keil debug and utilities configuration to use the ST-Link.
    I then tryed to program and the com light starts to flash but then stops and keil hangs on load and does not program the device.
    Any ideas??
    kkraus
    Did find the problem? Same here ... IAR works fine. Keil 4.x dont...
    kkraus
    ramadevi
    Did u succeed in this?
    ramadevi
    Yes, I have succeeded in this.
    I updated the STlink firmware version from
    http://www.st.com/mcu/familiesdocs-110.html
    and also upgraded the Keil IDE to 4.10.
