Using Segger Jlink pins as GPIO's
I am developing a project that has M7 processor. I want to use Segger Jlink pin which is JDTI as GPIO.
I want to keep it low until I set it. But, while flashing the code to my MCU, JDTI pin becomes high until passing the hal_initialize() function. So my corresponding hardware in JDTI pin powers itself due to pins setting itself situation while flashing the code. After passing hal_initialize() function it becomes low as expected and I can set and use it as GPIO pin.
So, is there any way to keep this pin low while flashing the code to my MCU.
Preferably, I want to solve this situation by software. It may need a hardware development too. If it is, please share your idea and lets discuss it. Any idea will be appreciated.
