aeolia_amha
using fprintf problem
Posted on June 18, 2010 at 09:15
    trevor23
    Posted on May 17, 2011 at 13:55
    Please be more specific. How are you sending this time number? Serial I preaume (UART)? Are you sending this number in ascii or binary format ? If ascii than assuming the number is received into a buffer called buffer that is null terminated the code to set the time would look something like this
    RTC_SetCounter( (u32)atol(buffer) );
