using 32 MHz crystall with STM32L011K4
In a project I need a precise timing so I cant rely on th internal oscilator and want
to use a crystal 24-32MHz with MCU. But actually I couldnt find anything about this possibility in datasheet.
the sample is 32 KHz that is not good for my application. Anyone knows is it possible or not. if yes could you point which pins the crystal should be connected?
Also in CubeMx/Clock Configuration I couldnt enable HSE, the circle is disabled.
thanks.
