k_hraj
USB stick access using STM32F205ZC
Posted on August 23, 2011 at 13:41
I want to access USB stick using STM32F205ZC. Whether keilV4.20 and st-link debugger will support debugging for OTG or not any suggestions please.
    August 23, 2011
    Posted on August 23, 2011 at 15:58
    Depends on what debugging you expect it to be able to do.
    If it is timing sensitive, then a debugger pod stepping or breakpointing is too invasive. Suggest you attach a serial terminal, and output controllable levels of debug/telemetry data.
    Have a U-Link or J-Link to hand in case the ST-LINK doesn't cut it. Frankly I've found the ST-LINK's to be more than adequate, but then I'm not constantly single-stepping my own code to figure out how it works. YMMV
    k_hraj
    k_hrajAuthor
    Posted on August 24, 2011 at 06:00
    Thanks for your valuable information and suggestions!
    k_hraj
    k_hrajAuthor
    Posted on August 25, 2011 at 10:37
    Is it preferable to consider
     STM32F105VC or
     STM32F107VC (OTG) for
    USB stick access?
    (are there are any limitations or problems we may get if I use these ICs)
