kjepsen9
USB Pullup ressistor
  • June 15, 2008
  • 521 views
Posted on June 15, 2008 at 11:30
    kjepsen9
    kjepsen9Author
    Posted on May 17, 2011 at 12:37
    For my custom board i like to remove the software connect/disconnect and only have the 1.5K pull up resistor.
    must it be pulled up to 3V3 or the 5V from the usb?
    Kasper
    16-32micros
    Hi kasper,
    Have a look on Datasheet , Section USB characteristics; D+ Should be pulled to 3V3 volts ( your VDD) . Hope this helps you for your Board design.
    Cheers,
    STOne-32.
