USB problems
Posted on January 05, 2017 at 13:59
I use a TUSB2046BVF to connect a host (tablet) to 2 USB connectors and 2 micros, one is STM32F103 and the otherSTM32F107, and I can only operate the 103 when I remove the pull-up resistor at 107.The other ports do not work, nor the 107 when I remove the pull-up to 103.I'm stuck with this problem.Thanks in advance.
#stm32f103-
