liqing
USB of STM3210B-EVAL
  • June 15, 2008
  • 3 replies
  • 832 views
Posted on June 16, 2008 at 00:22
    liqing
    liqingAuthor
    Posted on May 17, 2011 at 12:37
    The demonstation software was downloaded from ST website, I selected the power supply from USB port, it's work well, I think the power supply and BOOT option are correct, as well as flash memory. JP1 is ok, too. My PC must havn't driver because my PC can't recognize the new hardware. So my question is why my PC can't recognize the target board? It must install MSD card at first? I havn't install anything yet, just plug into USB port.
    embeddednotes
    The reasons are simple:
    1.Programming the flash memory.
    2.Your PC doesn't have drivers.
    3.If you are using the Demo version from st then it was working properly.
    4.Check the BOOT options, power supply to the board and Check the JP1 jumper settings for USB.
    liqing
    liqingAuthor
    why PC can't recognize the demo board? I put already D+ up by jumper. it show ''unknown device'' in computer management.
