muralij21
USB is not getting detected
Posted on October 06, 2010 at 09:22
    hli
    Posted on May 17, 2011 at 14:10
    If you mean no detection at all, try the resistor but once it is detected but not recognized, please have a look on the USB PLL clock.
    xacc
    Make sure you have the pullup on the data pins turned on (depending on USB speed, this will be on different lines).
    muralij21
    muralij21Author
    I connected the pull up resistor of 1.5k from D+ to VSSA. I got a warning msg ''One of the USB devices attached to this computer has malfunctioned and windows does not recognise it''
    greg_t
    you need pull up on your D+ line
    muralij21
    muralij21Author
    xacc
    VSSA is Analog Ground. It need 3.3V for a pullup.
    You should connect it to a GPIO pin that you can toggle.
    muralij21
    muralij21Author
    I tried it but still i am getting the same error. Any other suggestions..? please
