ashley23
USB FS Library Help Please
  • September 21, 2010
  • 665 views
Posted on September 22, 2010 at 00:24
    stforum2
    May 17, 2011
    Posted on May 17, 2011 at 14:08
    Only isochronous endpoints can send or receive packets greater than 64bytes in size.
    ashley23
    ashley23Author
    Fortunately for us the library is smart enough to know this and breaks the transmission up into smaller packets.  It turns out that if you call USB_Sil_write() with a big block (eg 1024 bytes) it sends the data block by block and everything works fine.  An IN EP callback is generated at the end of transmission to let you know it is done.  Pretty good huh?
