tager
Sep 6, 2013 7:23 PM UTC
USB FS core and HS core simultaineously
Posted on September 06, 2013 at 21:23
Since the STM32F407 has 2 USB ports, OTG_FS and OTG_HS, can both ports run at the same time? I want OTG_FS to operate as a host and OTG_HS to operate as a device at the same time.
All of the sample code from ST operates with either the FS core or the HS core, but not both at the same time.
    dimax
    Sep 7, 2013 10:25 AM UTC
    Posted on September 07, 2013 at 12:25
    HI,
    We are also going to this and to my understanding there should not be a problem as FS and HS cores have a separated register sets and separate PHY's
    Sep 7, 2013 10:31 AM UTC
    Posted on September 07, 2013 at 12:31
    I suspect it should be fine, I have seen boards with both, but it presupposes a level of USB and code implementation experience/expertise beyond the scope of the simple examples.
