USART1 interrupt
Posted on November 04, 2015 at 19:42
Hi to all,
I am encountering a problem using USART1 interrupt.
I can correctly send data on tx line and I woul like to use interrupt to receive data from rx line. I enabled RXNEIE bit in CR1 and created the handler extern ''C'' void USART1_IRQHandler() // I am using C++ { myled.LedOn(LED4); Delay(1000); myled.LedOff(LED4); return; } but nothing happened. Do I have to enable something else? Thank you Freya
