hexanpro2
Feb 19, 2010 4:23 PM UTC
USART STM32 asynchonous mode
Posted on February 19, 2010 at 17:23
    Andrew Neil
    May 17, 2011 11:40 AM UTC
    Posted on May 17, 2011 at 13:40
    It would be polite to acknowledge the help that you've already received on this:
    http://raisonance-forum.xsalto.com/viewtopic.php?id=3179
    The USART Data Register (DR) is 16-bits wide, to accommodates all 9 bits (
    D0
    D8
    You should always write the DR as an ''unsigned short'' or ''u16'', if using DMA the 9-bit mode would require you send Half Words, not Bytes.
    -Clive
    * Function Name  : USART_SendData
    * Description    : Transmits single data through the USARTx peripheral.
    * Input          : - USARTx: Select the USART or the UART peripheral.
    *                    This parameter can be one of the following values:
    *                     - USART1, USART2, USART3, UART4 or UART5.
    *                  - Data: the data to transmit.
    * Output         : None
    * Return         : None
    void USART_SendData(USART_TypeDef* USARTx, u16 Data)
      /* Check the parameters */
      assert_param(IS_USART_ALL_PERIPH(USARTx));
      assert_param(IS_USART_DATA(Data));
      /* Transmit Data */
      USARTx->DR = (Data & (u16)0x01FF);
    Andrew Neil
    May 17, 2011 11:41 AM UTC
    Posted on May 17, 2011 at 13:41
    There is an example of using the USART in Multiprocessor Mode (ie, 9-bit mode) included in the Standard Peripheral Library:
    Project\STM32F10x_StdPeriph_Examples\USART\MultiProcessor
    hexanpro2
    hexanpro2Author
    Thanks, for your anwser and your time...
    I base my communications in this base, and this saves me a lots af time...
    Thanks for your time, once more...
    My complements...
    Andrew Neil
    Have you read the description of the Multiprocessor Mode in the RM0008 Reference Manual?
