Feb 11, 2019 12:59 PM UTC
I don't believe the two are connected, perhaps expand on the detail, with minimal code example, so the issue might be reviewed or replicated. ​
sG.12
sG.12Author
Feb 12, 2019 4:17 AM UTC
#include "main.h"
#include "stm32f1xx_hal.h"
CAN_HandleTypeDef hcan1;
WWDG_HandleTypeDef hwwdg;
UART_HandleTypeDef huart1;
static CanTxMsgTypeDef myTxMessage;
static CanRxMsgTypeDef myRxMessage;
static CAN_FilterConfTypeDef myFilter;
 uint32_t j;
uint8_t *Rcbuff;
 uint8_t id,dlc,data[8];
static void MX_WWDG_Init(void);
static void MX_CAN1_Init(void);
static void MX_USART1_UART_Init(void);
int main(void)
 HAL_Init();
 SystemClock_Config();
 MX_GPIO_Init();
 MX_WWDG_Init();
 MX_CAN1_Init();
 MX_USART1_UART_Init();
 myFilter.FilterNumber = 0;
 myFilter.FilterMode = CAN_FILTERMODE_IDMASK;
 myFilter.FilterScale = CAN_FILTERSCALE_32BIT;
 myFilter.FilterIdHigh = 0x0000;
 myFilter.FilterIdLow = 0x0000;
 myFilter.FilterMaskIdHigh = 0x0000;
 myFilter.FilterMaskIdLow = 0x0000;
 myFilter.FilterFIFOAssignment = 0;
 myFilter.FilterActivation = ENABLE;
 HAL_CAN_ConfigFilter(&hcan1,&myFilter);
 hcan1.pTxMsg = &myTxMessage;
 myTxMessage.DLC = 8;
 myTxMessage.StdId = 0x123;
 myTxMessage.IDE = CAN_ID_STD;
 myTxMessage.RTR=CAN_RTR_DATA;
 myTxMessage.Data[0]=0xAB;
 myTxMessage.Data[1]=0xCD;
 myTxMessage.Data[2]=0xEF;
 myTxMessage.Data[3]=0xAA;
 myTxMessage.Data[4]=0xBB;
 myTxMessage.Data[5]=0xCC;
 myTxMessage.Data[6]=0xDD;
 myTxMessage.Data[7]=0xEE;
 //HAL_CAN_Transmit_IT(&hcan1);
 HAL_Delay(1000);
 while (1)
 Rcbuff=HAL_CAN_Receive_IT(&hcan1,CAN_FIFO0);
HAL_UART_Transmit(&huart1,Rcbuff,15,10);
 HAL_Delay(100);
 huart1.Instance = USART1;
 huart1.Init.BaudRate = 9600;
 huart1.Init.WordLength = UART_WORDLENGTH_8B;
 huart1.Init.StopBits = UART_STOPBITS_1;
 huart1.Init.Parity = UART_PARITY_NONE;
 huart1.Init.Mode = UART_MODE_TX_RX;
 huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
 huart1.Init.OverSampling = UART_OVERSAMPLING_16;
 __HAL_UART_ENABLE_IT( &huart1,UART_IT_TXE) ;
 if (HAL_UART_Init(&huart1) != HAL_OK)
 _Error_Handler(__FILE__, __LINE__);
void SystemClock_Config(void)
 RCC_OscInitTypeDef RCC_OscInitStruct;
 RCC_ClkInitTypeDef RCC_ClkInitStruct;
 RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
 RCC_OscInitStruct.HSEState = RCC_HSE_ON;
 RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV5;
 RCC_OscInitStruct.HSIState = RCC_HSI_ON;
 RCC_OscInitStruct.Prediv1Source = RCC_PREDIV1_SOURCE_PLL2;
 RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
 RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
 RCC_OscInitStruct.PLL2.PLL2State = RCC_PLL2_ON;
 RCC_OscInitStruct.PLL2.PLL2MUL = RCC_PLL2_MUL8;
 RCC_OscInitStruct.PLL2.HSEPrediv2Value = RCC_HSE_PREDIV2_DIV5;
 RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
 RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
 if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
 HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
 HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
 __HAL_RCC_PLLI2S_ENABLE();
 HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
 hcan1.Instance = CAN1;
 hcan1.Init.Prescaler = 16;
 hcan1.Init.Mode = CAN_MODE_NORMAL;
 hcan1.Init.SJW = CAN_SJW_1TQ;
 hcan1.Init.BS1 = CAN_BS1_5TQ;
 hcan1.Init.BS2 = CAN_BS2_3TQ;
 hcan1.Init.TTCM = DISABLE;
 hcan1.Init.ABOM = DISABLE;
 hcan1.Init.AWUM = DISABLE;
 hcan1.Init.NART = DISABLE;
 hcan1.Init.RFLM = DISABLE;
 hcan1.Init.TXFP = DISABLE;
 if (HAL_CAN_Init(&hcan1) != HAL_OK)
 hwwdg.Instance = WWDG;
 hwwdg.Init.Prescaler = WWDG_PRESCALER_8;
 hwwdg.Init.Window = 0x40;
 hwwdg.Init.Counter = 0x40;
 hwwdg.Init.EWIMode = WWDG_EWI_DISABLE;
 if (HAL_WWDG_Init(&hwwdg) != HAL_OK)
 GPIO_InitTypeDef GPIO_InitStruct;
 /* GPIO Ports Clock Enable */
 __HAL_RCC_GPIOD_CLK_ENABLE();
 __HAL_RCC_GPIOC_CLK_ENABLE();
 __HAL_RCC_GPIOA_CLK_ENABLE();
 __HAL_RCC_GPIOB_CLK_ENABLE();
 HAL_GPIO_WritePin(nCAN2_STB_GPIO_Port, nCAN2_STB_Pin, GPIO_PIN_RESET);
 GPIO_InitStruct.Pin = HS_LS_IN_Pin;
 GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
 HAL_GPIO_Init(HS_LS_IN_GPIO_Port, &GPIO_InitStruct);
 GPIO_InitStruct.Pin = S2_IN_Pin;
 HAL_GPIO_Init(S2_IN_GPIO_Port, &GPIO_InitStruct);
 GPIO_InitStruct.Pin = nCAN2_STB_Pin;
 HAL_GPIO_Init(nCAN2_STB_GPIO_Port, &GPIO_InitStruct);
 GPIO_InitStruct.Pin = CAN2_ERR_IN_Pin;
 HAL_GPIO_Init(CAN2_ERR_IN_GPIO_Port, &GPIO_InitStruct);
void _Error_Handler(char *file, int line)
 while(1)
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
#endif
This is our code.
Feb 12, 2019 4:26 AM UTC
So some arbitrary delays, no interrupt or callback code, doesn't wait/check status and doesn't kick the watchdog.
Turns status to a pointer, outputs data from random pointer.
