Chuev.Vladimir
Updating firmware using raspberry pi
  • January 11, 2021
  • 1232 views
I have a custom board with SWO pins for STM32 firmware (but I don't have the RESET pin)
I was planning to update my board remotely with ST-Link and raspberry pi
But I found out too late that STM32CubeProgrammer does not support ARM
I tried to use ST-Link Utility but couldn't work it with Soft Reset
Is there a way out? I don't want to order a new board
    KnarfB
    Should be possible using OpenOCD from sources for Raspi like here: https://iosoft.blog/2019/01/28/raspberry-pi-openocd/
    January 11, 2021
    Perhaps you can just add code to your own firmware (loader+app) so it can update itself rather than relying on SWD/JTAG or the System Loader.
    ie some sort of IAP / FOTA type affair, where you control ALL the variables, and can write code for whatever platform you choose.
