edgar2
Oct 30, 2012 12:32 PM UTC
unsigned_int and unsigned_short_int compatibility ?
Posted on October 30, 2012 at 13:32
Hi there,
May be this is a silly question, but could someone explain me to how we use unsigned int and unsigned short int types together ? Here is an exemple from a simple working code (gpio.c* of STM32 VL Discovery MCU). In this code, I put in comments the questions running through my head.
volatile
unsigned
int
a;
unsigned
short
int
b;
unsigned
int
c;
unsigned
char
function_0()
if
( (a&b) != c)
// how is it possible to use a logic operation on two different types and then compare the result with an other type ?
else
unsigned
short
int
function_1(...)
return
( (unsigned
short
int
) a) ;
// As we convert one to the other, I understand from this line that the two types aren't compatible . right ?
void
function_2(...)
a = a | b;
// same question as for function_0().
a &= (~b);
(*) : I replaced the original variables : GPIO_x->IDR, GPIO_Pin and (unsigned int) )BIT_RESET with respectively: a, b, and c to make the code easier to read. I wish this was clear and I'd much appreciate your help. Thanks. #'c'-textbook-question #unsigned #short #int
    Andrew Neil
    Oct 30, 2012 1:17 PM UTC
    Posted on October 30, 2012 at 14:17
    This is a 'C' textbook question - nothing specifically to do with STM32.
    Suggested references:
    http://blog.antronics.co.uk/2010/12/12/things-you-shouldve-learned-in-c-class-0-introduction/
    Integer Promotion is the topic you're looking for...
    edgar2
    edgar2Author
    Oct 30, 2012 8:56 PM UTC
    Posted on October 30, 2012 at 21:56
    I'm sorry, thanks for the references.
