Unexpected data whith QSPI on STM32L431
I am experiencing some strange behavior when using the QSPI module to communicate with an Adesto Flash chip.
I am using the newest version of the ST HAL driver library.
- During the Dummy Cycles Phase, the SI pin is transmitting data. This is data is ignored by the Flash chip so this is not a problem but it is still unwanted.
- Even if the data size is set correctly in the QSPI module (DLR Register = 1) an additional byte is received by the QSPI module.
Anyone has an idea what causes this behavior?
