Aug 2, 2024 12:41 PM UTC
Unable to read and write STM32F411CEU6 blackpill board flash memory
Respected sir/madam,
We are using STM32F411CEU6 blackpill board. When we try to put our code into the flash, it says it the memory is protected. Can you suggest possible solution to solve the issue?
mƎALLEm
mƎALLEmBest answer
Apr 14, 2025 3:02 PM UTC
ST resources are dedicated to supporting genuine ST products. We are not committed to ensuring that clones/fakes work properly with the firmware we provide.
Thank you for your understanding.
Muhammed Güler
Senior III
Aug 2, 2024 12:48 PM UTC
Have you tried connecting to your board using STM32CubeProgrammer?
You can disable write protection by reprogramming the option bytes with STM32CubeProgrammer.
AkshayMRAuthor
Aug 3, 2024 4:35 AM UTC
We used STM32CubeProgrammer and tried to disable write protection by providing "AA" in optional bytes. But, "AA" is not taken and it shows only "FF" in optional bytes. How to overcome this issue?
Andrew Neil
Aug 2, 2024 1:06 PM UTC
warningyukihyo
Aug 3, 2024 10:53 AM UTC
  • Make sure that the firmware on ST-Link is up to date. (CubeProgrammer, too)
  • Enter bootloader mode with the BOOT0 button and try the operation.
  • Try changing the RDP flags after launch ERASE ALL in CubeProgrammer.
mƎALLEm
mƎALLEmBest answer
