unable to flash NUCLEO-H7A3ZI-Q
Hi Team,
we are facing issue with flashing NUCLEO-H7A3ZI-Q board.
is any problem if we flash stm32h7a3zit6 code on stm32h7a3zit6q.
can we give a suggestion ASAP
Hi @Chandramouli
STM32h7a3zit6q embeds SMPS power supply. So check in your code if SMPS is configured you can flash your code without issues
Thanks for quick response,
we did flash stm32h7a3zit6 code on stm32h7a3zit6q. then onwards NUCLEO-H7A3ZI-Q board not working,
compiler showing below message,
Target no device found
Error in initializing ST-LINK device.
Reason: No device found on target.
mƎALLEm
As stated by @FBL, what is the power configuration you set in your FW? LDO or SMPS?
mƎALLEm
we are facing issue with flashing NUCLEO-H7A3ZI-Q board.You need to provide
 You need to provide a details for that. Error message, or screen shots ..
I would suggest you connect to the target using CubeProg in Power Down mode and erase the flash.
