lehoangnguyen_bd
uclinux
Posted on December 02, 2009 at 05:43
uclinux
    g-ab
    May 17, 2011
    Posted on May 17, 2011 at 13:32
    >> ''/bin/sh: cc: command not found ''
    try to type cc -v in your shell to see if a gnu c compiler exist in your path.
    Try to install ''c development'' & ''kernel development'' packages from your fedora installation media.
    Regards,
    G-Ab.
    lehoangnguyen_bd
    Hi all !
    I am running uclinux image(build on the fedora 10 +linux) on my stm32e-eval board,but when i Configure uClinux for STM3210E-EVAL with somes error
    I don't know to process. how i do with this error
    ''config/mkconfig > Kconfig
    CC=cc CXX=c++ make -C /home/host_nguyen/wordspace/uClinux-dist/config/kconfig conf
    lxdialog/check-lxdialog.sh: line 9: cc: command not found
    make[1]: Entering directory `/home/host_nguyen/wordspace/uClinux-dist/config/kconfig'
    cc -DCURSES_LOC='''' -DKBUILD_NO_NLS -c -o conf.o conf.c
    make[1]: *** [conf.o] Error 127
    make[1]: Leaving directory `/home/host_nguyen/wordspace/uClinux-dist/config/kconfig'
    make: *** [/home/host_nguyen/wordspace/uClinux-dist/config/kconfig/conf] Error 2
    Thanks !
    Nguyen
