kasun_duminda92
Dec 30, 2012 8:28 PM UTC
UART received value conversion to float
Posted on December 30, 2012 at 21:28
I have been working on a program to directly transmit any character or set of characters that I transmit from the PC via UART, back to the PC immediately. This is just the first step in my project.
Code (this works):
    while(1) {
        int8_t buffer[20];
        scanf(''%s'', buffer);
        printf(''%s\n'', buffer);
        STM_EVAL_LEDToggle(LED4);
Next I want use the value I receive from the PC for some mathematical operations in 'float' data type.
Can anyone please tell me how to covert the value received 'buffer' to a float value?
'Thank You' in advance.
#tags-are-pointless #stm32f0-usart #lacks-specificity #connect-uart-to-pc
Dec 30, 2012 8:36 PM UTC
Posted on December 30, 2012 at 21:36
Presuming you have a decent tool chain with libraries that support floating point, and more specifically floating point support in scanf/printf
float flt;
sscanf(buffer,''%f'',&flt);
Or
double dbl;
dbl = atof(buffer);
Or you could do some decimal math and parse it yourself.
kasun_duminda92
Dec 30, 2012 8:44 PM UTC
Posted on December 30, 2012 at 21:44
Dec 30, 2012 10:21 PM UTC
Posted on December 30, 2012 at 23:21
Both of these methods give errors. I am going to try parsing.
Perhaps some specificity to the error, and the tool chain, might help arrive at a solution.
atof() is usually part of stdlib.h, at least on Keil. I'd probably be including math.h and stdlib.h, along with stdio.h
A quick Google would probably bring up source code for something like atof(), or a lightweight equivalent thereof.
http://code.google.com/p/unladen-swallow/source/browse/branches/release-2009Q1-maint/Python/atof.c
kasun_duminda92
Dec 31, 2013 8:58 AM UTC
Posted on December 31, 2012 at 09:58
