arro239
Sep 20, 2012 1:51 AM UTC
trying to understand EXTI example code
Posted on September 20, 2012 at 03:51
I have EXTI example running on my stm32f4 board but I am having trouble changing the PIN which causes the interrupt.
Here is the initialization method:
void EXTILine0_Config(void)
  GPIO_InitTypeDef   GPIO_InitStructure;
  NVIC_InitTypeDef   NVIC_InitStructure;
  /* Enable GPIOA clock */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
  /* Enable SYSCFG clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  /* Configure PA0 pin as input floating */
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Connect EXTI Line0 to PA0 pin */
  SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource0);
  /* Configure EXTI Line0 */
  EXTI_InitStructure.EXTI_Line = EXTI_Line0;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable and set EXTI Line0 Interrupt to the lowest priority */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x01;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x01;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
I am trying to change the replace GPIO_Pin_0 in ''GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;'' but still - my led is controlled via the same user button, and via applying +3 to PA0, not any other PA pin. I have even tried changing EXTI_PinSource0 - same thing, only PA0 causes the interrupt. I have double checked that I am in fact rebuilding and reflashing a couple of times - I can easily change which LED I control with the EXTI, this confirm that I am in fact do execute the new binary.
What am I missing here?
#pa0 #falling-edge #interrupts
Mar 10, 2015 3:53 PM UTC
Posted on March 10, 2015 at 16:53
I have no insight into your board design, or code. You have posted to a >2 year old thread about a different chip.
tranvanduy
Mar 10, 2015 6:22 PM UTC
Posted on March 10, 2015 at 19:22
Hihi, thank Mr Clive1 so much, I will check my problem again!
Have fun!
tranvanduy
Mar 11, 2015 4:52 AM UTC
Posted on March 11, 2015 at 05:52
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6lJ&d=%2Fa%2F0X0000000buo%2FDCJBwL8Kl_0qGtAEMZ_jSXyRHTXV1EN7BIx3.pc4t1M&asPdf=false
Beck.Karl-Michael
Mar 26, 2015 10:29 AM UTC
Posted on March 26, 2015 at 11:29
I'm currently also trying to setup a Interrupt by configuring the Registers of the cpu.
Inthe code above i see a function SYSCFG_EXTILineConfig. I just downloaded the latest board Support package (stm32cubef4 1.5.0.) and there is no such function. Where does this function come from? Also i'm missing the
NVIC_Init
function. I only have HAL_GPIO_Init and a bunch of registers. ^^
Mar 26, 2015 12:16 PM UTC
Posted on March 26, 2015 at 13:16
This thread is about using the
http://www.st.com/web/en/catalog/tools/PF257901
, not the HAL/Cube implementation.
Beck.Karl-Michael
Mar 26, 2015 3:10 PM UTC
Posted on March 26, 2015 at 16:10
Thanks for the help.
