VNado.1
Dec 21, 2020 11:40 PM UTC
Trying to integrate the waveplayer from stm32137 example in L4+ MCU. However, the loop updating the DMA buffer only enters DMATxComplete on 3 occasions?
Here's the essence of what I have at the moment. I wonder why it does not enter DMATxComplete, I have tried with 128 and 30 buffer sizes...
//****** dac.c **********//
DAC_HandleTypeDef hdac1;
DMA_HandleTypeDef hdma_dac_ch1;
DMA_HandleTypeDef hdma_dac_ch2;
/* DAC1 init function */
void MX_DAC1_Init(void)
 DAC_ChannelConfTypeDef sConfig;
 /**DAC Initialization
 hdac1.Instance = DAC1;
 if (HAL_DAC_Init(&hdac1) != HAL_OK)
 _Error_Handler(__FILE__, __LINE__);
 /**DAC channel OUT1 config
 sConfig.DAC_SampleAndHold = DAC_SAMPLEANDHOLD_DISABLE;
 sConfig.DAC_Trigger = DAC_TRIGGER_T6_TRGO;
 sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_ENABLE;
 sConfig.DAC_ConnectOnChipPeripheral = DAC_CHIPCONNECT_DISABLE;
 sConfig.DAC_UserTrimming = DAC_TRIMMING_FACTORY;
 sConfig.DAC_HighFrequency = DAC_HIGH_FREQUENCY_INTERFACE_MODE_ABOVE_80MHZ;
 if (HAL_DAC_ConfigChannel(&hdac1, &sConfig, DAC_CHANNEL_1) != HAL_OK)
 /**DAC channel OUT2 config
 sConfig.DAC_Trigger = DAC_TRIGGER_T7_TRGO; //T7
 if (HAL_DAC_ConfigChannel(&hdac1, &sConfig, DAC_CHANNEL_2) != HAL_OK)
void HAL_DAC_MspInit(DAC_HandleTypeDef* dacHandle)
 GPIO_InitTypeDef GPIO_InitStruct;
 if(dacHandle->Instance==DAC1)
 /* USER CODE BEGIN DAC1_MspInit 0 */
 /* USER CODE END DAC1_MspInit 0 */
 /* DAC1 clock enable */
 __HAL_RCC_DAC1_CLK_ENABLE();
 __HAL_RCC_GPIOA_CLK_ENABLE();
 /**DAC1 GPIO Configuration
 PA4 ------> DAC1_OUT1
 PA5 ------> DAC1_OUT2
 GPIO_InitStruct.Pin = DAC_OUT1_Pin | DAC_OUT2_Pin;
 GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
 /* DAC1 DMA Init */
 /* DAC_CH2 Init */
 hdma_dac_ch2.Instance = DMA2_Channel5;
 hdma_dac_ch2.Init.Request = DMA_REQUEST_DAC1_CH2; //DMA_REQUEST_3;
 hdma_dac_ch2.Init.Direction = DMA_MEMORY_TO_PERIPH;
 hdma_dac_ch2.Init.PeriphInc = DMA_PINC_DISABLE;
 hdma_dac_ch2.Init.MemInc = DMA_MINC_ENABLE;
 hdma_dac_ch2.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
 hdma_dac_ch2.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
 hdma_dac_ch2.Init.Mode = DMA_CIRCULAR;
 hdma_dac_ch2.Init.Priority = DMA_PRIORITY_HIGH;
 if (HAL_DMA_Init(&hdma_dac_ch2) != HAL_OK)
 __HAL_LINKDMA(dacHandle,DMA_Handle2,hdma_dac_ch2);
 /* DAC_CH1 Init */
 hdma_dac_ch1.Instance = DMA1_Channel3;
 hdma_dac_ch1.Init.Request = DMA_REQUEST_DAC1_CH1; //DMA_REQUEST_6;
 hdma_dac_ch1.Init.Direction = DMA_MEMORY_TO_PERIPH;
 hdma_dac_ch1.Init.PeriphInc = DMA_PINC_DISABLE;
 hdma_dac_ch1.Init.MemInc = DMA_MINC_ENABLE;
 hdma_dac_ch1.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
 hdma_dac_ch1.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
 hdma_dac_ch1.Init.Mode = DMA_NORMAL;
 hdma_dac_ch1.Init.Priority = DMA_PRIORITY_HIGH;
 if (HAL_DMA_Init(&hdma_dac_ch1) != HAL_OK)
 __HAL_LINKDMA(dacHandle,DMA_Handle1,hdma_dac_ch1);
 /* USER CODE BEGIN DAC1_MspInit 1 */
 /* Enable Transfer Complete on channel 3 */
 //DMA_ITConfig(DMA1_Channel3, DMA_IT_TC, ENABLE);
 /* USER CODE END DAC1_MspInit 1 */
void Audio_MAL_Play(uint32_t * signal, uint32_t size)
 if(HAL_DAC_Stop_DMA(&hdac1, DAC_CHANNEL_1) != HAL_OK)
 Error_Handler();
 if(HAL_TIM_Base_Stop(&htim6) != HAL_OK)
 Error_Handler();
 /* Disable DMA1 Channel3 */
 //HAL_DMA_Abort(DMA1_Channel3);
 /* Enable DMA1 Channel3 */
 //HAL_DMA_Start(DMA1_Channel3);
 if (HAL_DAC_Start_DMA(&hdac1, DAC_CHANNEL_1, signal, size, DAC_ALIGN_12B_R) != HAL_OK) // 12B_L or 12B_R?
	 /* Start DMA Error */
 Error_Handler();
 // Set the timer period to the default
 htim6.Instance->ARR = ARR_FILE; // replace with htim7?
 if(HAL_TIM_Base_Start(&htim6) != HAL_OK) // replace with htim7
	 Error_Handler();
void start_DAC_us(uint32_t * signal, uint32_t size)
	 Error_Handler();
	// Only playback Sine Wave on DAC Channel 2, DAC Channel 1 will playback AudioTrack
 if (HAL_DAC_Start_DMA(&hdac1, DAC_CHANNEL_2, signal, size, DAC_ALIGN_12B_R) != HAL_OK) // input a second signal for DAC channel 2
 Error_Handler();
 htim7.Instance->ARR = ARR_SIN; //Channel2 - Sine Wave
 if(HAL_TIM_Base_Start(&htim7) != HAL_OK) // replace with htim7
 Error_Handler();
 htim6.Instance->ARR = ARR_FILE; //Channel1 - Audio File
 	 Error_Handler();
//****** In function.c **********//
start_DAC_us( (uint32_t *)Sine12bit, SIZE_LUT);
Audio_MAL_Play((uint32_t*)Sine12bit, SIZE_LUT);
	BufferSelection = 2;
				do
					if(BufferRead != 0)
						/* Play sine test */
//						Audio_MAL_Play( (uint32_t *)Sine12bit, SIZE_LUT);
//						BufferRead = 0;
					 if(BufferSelection == 2)
					 /* Play buffer 2 */
					 BufferRead = 0;
					 else if (BufferSelection == 1)
					 	/* Play buffer 1 */
					 BufferRead = 0;
				}while((FlagBits & FLAG_TOGGLE_US));
void WavePlayer_DMATxComplete_IRQHandler(void)
 if(__HAL_DMA_GET_FLAG(&hdma_dac_ch1,DMA_FLAG_TC3))
 BufferSelection = 1;
 BufferRead = 1;
 else
 BufferRead = 1;
 __HAL_DMA_CLEAR_FLAG(&hdma_dac_ch1,DMA_FLAG_TC3);
VNado.1
VNado.1Author
Dec 22, 2020 6:53 PM UTC
When I set DMA for DAC_Ch1 as a circular buffer it enters WavePlayer_DMATxComplete_IRQHandler constantly. However, when I set the DMA as a "normal" buffer, it only enters it at the beginning. It is supposed to do reset BufferRead = 1, since it does not enter the function it gets stuck without any output at the DAC.
I have added the following code to init the DMA NVIC for interrupts, without further success:
void WavePlayer_Init(void)
 /********************************* DMA Config *******************************/
 /* DMA1 clock enable (to be used with DAC) */
 RCC->AHB1ENR |= RCC_AHB1ENR_DMA1EN; //Enable DMA1 Clock //RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
 /* DMA channel3 Configuration is managed by Audio_MAL_Play() function */
 HAL_NVIC_SetPriority(DMA1_Channel3_IRQn, 0, 0);
 HAL_NVIC_EnableIRQ(DMA1_Channel3_IRQn);
 __HAL_DMA_ENABLE_IT(&hdma_dac_ch1,DMA_IT_TC);
How can I debug this? How can I know where the DMA Tx complete fails?
waclawek.jan
Dec 22, 2020 8:18 PM UTC
Quite likely, DAC underruns. Read out and check the DMA and DAC registers content, focus on status bits in both.
VNado.1
VNado.1Author
Dec 22, 2020 11:41 PM UTC
Where can I find the DMA and DAC registers content? I have looked in HAL_DMA_Start_IT() and I am not sure I know where to focus.
waclawek.jan
Dec 23, 2020 7:56 AM UTC
I said, read out.
The easiest way is to use the register view in debugger.
