gareth
Dec 16, 2008 12:27 PM UTC
triggering adc1 from Timer 1 Capture Compare Interupt
Posted on December 16, 2008 at 13:27
    brianforde9
    May 17, 2011 10:51 AM UTC
    Posted on May 17, 2011 at 12:51
    Site wont let me attach C file, but I could attach a gzip file. Go figure...
    Brian F.
    brianforde9
    I'm out of ideas. The only otehr difference I can see between yours and mine, is wherer I call ADC_DMACmd(). I don't call it until after the calibration is complete.
    Try triggering a single conversion only
    ADC_DeInit(ADC1);
    lsADC_InitStruct.ADC_Mode = ADC_Mode_Independent;
    lsADC_InitStruct.ADC_ScanConvMode = DISABLE;
    lsADC_InitStruct.ADC_ContinuousConvMode = DISABLE;
    lsADC_InitStruct.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC3;
    lsADC_InitStruct.ADC_DataAlign = ADC_DataAlign_Right;
    lsADC_InitStruct.ADC_NbrOfChannel = 1;
    ADC_Init(ADC1, &lsADC_InitStruct);
    ADC_RegularChannelConfig(ADC1,ADC_Channel_0, 1,ADC_SampleTime_55Cycles5);
    etc...
    gareth
    garethAuthor
    Hi all, sorry for the very late reply on this topic. I finaly found a solution/the problem a few weeks back. It seems that on the MCBSTM32E eval board not all the GPIO pins are physicaly connected to their labelled pads. This was the case with the interupt line i was attempting to use and hence the issue.
    Hope that helps
    gareth
    garethAuthor
    Cheers for your help Brian.
    I shall look into this further today and get back to you
