DOsbo
Tricky FMC Question
When connecting a parallel FLASH device to the micro the address mappings are thus:
For a NOR FLASH device with an 8 bit data bus, the internal address (FMC_Ax) maps directly to the micro hardware pins (HW_Ax).
8-Bit Data Bus
FMC_A0 => HW_A0 ======> FL_A0
FMC_A1 => HW_A1 ======> FL_A1
FMC_A24 => HW_A24 ======> FL_A24
FMC_A25 => HW_A25 ======> FL_A25
For a NOR FLASH device with a 16 bit data bus, the micro shifts the internal address right 1 bit. Effectively, you get the mapping below:
16-Bit Data Bus
FMC_A1 => HW_A0 ======> FL_A0
FMC_A2 => HW_A1 ======> FL_A1
FMC_A25 => HW_A24 ======> FL_A24
???? =>HW_A25 ===?
My question is what signal is placed on HW_A25? If it's nothing, can that pin be re-assigned for a different function?
Cheers
David
waclawek.jan
waclawek.janBest answer
Probably a fixed level. Did not try.
 Yes; as any other pin you don't need (e.g. when using a smaller memory).
waclawek.jan
DOsbo
DOsboAuthor
Ok JW, thanks for your prompt reply.
