tran
Dec 22, 2009 10:26 AM UTC
Tool flasher Cortex M3
Posted on December 22, 2009 at 11:26
    armmcu
    May 17, 2011 11:33 AM UTC
    Posted on May 17, 2011 at 13:33
    Hi
    I don’t have in mind some commercialized tools.
    But I guess this could be feasible using another STM32 acting as a programmer (master).Through a simple program inspired from the IAP programming application note you can program STM32 targets (slaves) through USART by the STM32 (master), so you can baypass the PC.
    Cheers.
    tran
    tranAuthor
    I want to find a tool that can programme the flash of my STM32F101R6. When i make some recherche on the site of SEGGER : Jflash software=400€+ Flash ARM 600 ( that can programme in stand-alone). It's so expensive to us and we cant invest an amount like this in the beginning.
    Do you all have some goods ideas ? It should be the best if we can find out a tool who can programme without pc==> We have to use pc to programme it in the first time only and then the tool can work independent.
    Thanks all,
    swhite
    If you don't want debug capability you could use the STM32F internal bootloader to load your code serially.
    See
    http://www.st.com/mcu/forums-cat-9233-23.html
    for a tool/software.
    Here's the
    http://www.er-tronik.de/shop2/product_info.php?cPath=34&products_id=113
    to the programmer.
    [ This message was edited by: swhite on 09-12-2009 20:24 ]
    tomas23
    STLink should be very cheap. Or Wiggler, or Olimex tool?
    tran
    tranAuthor
    Thanks all
    Your infos is very useful==> I'm studying about your solutions.
    Quyen
    ahnniu
    Hi tran.thequyen,
    there is a Free stand-alone Cortex M3 Flash Programming softeware,
    http://www.coocox.org/CoFlash_Programmer.htm
    , Using an open
    http://www.coocox.org/Colink.htm
    ,based on the FT2232. It has an intuitive user interface with a traditional Windows graphical user interface (GUI), and a command line mode as well.
    Open JTAG hardware debugging probe,CooCox Colink:
    Free Cortex M3 FlashProgrammer:
    ,Cooperate on Cortex,providing free and open ARM development tools.
    [ This message was edited by: ahnniu on 10-12-2009 01:56 ]
    mcuisp
    Dear Quyen:
    I had develope a stand-alone programmer:EP868,can use for program STM32 without PC. it support JTAG/SWD,and Uart ISP also.
    Further more, it support stand-alone program for STM8S also.
    with www.mcuisp.com, you can find more info.
    James Peng
    www.mcuisp.com
