moez0102
Jul 12, 2018 12:55 PM UTC
TIMx_CH1_ETR vs TIMx_CH1
Posted on July 12, 2018 at 14:55
Could you explain me the difference between TIMx_CH1_ETR and TIMx_CH1, please?
In deed, I would like to replace STM32L071 with STM32F091 (PA0 - pin n°14).
In general, I would like to connect an external clock to a timer pin. My goal is to use the timer alone when the processor in Idle mode to save power. So, could I use TIMx_CH1_ETR or TIMx_CH1 or both are allowed, please?
    waclawek.jan
    Jul 12, 2018 2:09 PM UTC
    Posted on July 12, 2018 at 16:09
    TIMx_CH1_ETR is a - somewhat confusing - way to tell, that this pin is connected internally to *both* the CH1 and the ETR nodes of the TIMx module.
    In other words, as long as you don't use any of the ETR functions, you can use TIMx_CH1_ETR in exactly the same way as you use TIMx_CH1.
    moez0102
    moez0102Author
    Jul 13, 2018 9:24 AM UTC
    Posted on July 13, 2018 at 09:24
    Thanks,
    However, when we use
    TIMx_ETR and when we use
    TIMx_CH1 in general, please?
