Timmer input STM32F429
Fig 9 of the STM32F429 datasheet it effectively states that the external source clock/signal has to be 1/3 of the Timer clock – makes sense as you want to ensure you capture the edge of the input signal.
However, the Ref manual section 17.4.3, the reg setting(bits 12 and 13)for the timer states that the external trigger must be ¼ of the timer clock
Are they contradicting themselves or are they referring to two different things?
