mark_verheyen
Timer update event interrupt retriggering after exit.
Posted on January 21, 2011 at 20:18
    mark_verheyen
    Posted on May 17, 2011 at 14:22
    Great!  Thank you for the thorough explanation.  Would it be possible to put this level of detail in the technical manual?
    Mark
    etienne2
    July 2, 2014
    Posted on July 02, 2014 at 11:19
    The relevant faq entry has been moved:
    https://my.st.com/public/Faq/Lists/faqlst/DispForm.aspx?ID=143
    July 2, 2014
    Posted on July 02, 2014 at 13:26
    As a clickable link
    I'll note that the suggestion to use bit-banding is probably a bad one, and particularly dangerous for TIMx->SR cases as it's only atomic from the processors perspective. It can result in dismissing interrupts that pend in the 4 or whatever cycles between the read/write
