Oct 28, 2025 12:25 PM UTC
Timer synchronization failure when using different ARR value
I'm trying to use 2 timers (TIM1, TIM8) in sync.
Everything works OK when using same value for both timers' ARR.
But drift occurs when using two different values as ARR (i.g. 3999 for TIM1 & 19999 for TIM8).
What could be causing this drift?
tim.c
/* TIM1 init function */
void MX_TIM1_Init(void)
 /* USER CODE BEGIN TIM1_Init 0 */
 /* USER CODE END TIM1_Init 0 */
 LL_TIM_InitTypeDef TIM_InitStruct = {0};
 LL_TIM_OC_InitTypeDef TIM_OC_InitStruct = {0};
 LL_TIM_BDTR_InitTypeDef TIM_BDTRInitStruct = {0};
 /* Peripheral clock enable */
 LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_TIM1);
 /* TIM1 interrupt Init */
 NVIC_SetPriority(TIM1_UP_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
 NVIC_EnableIRQ(TIM1_UP_IRQn);
 /* USER CODE BEGIN TIM1_Init 1 */
 /* USER CODE END TIM1_Init 1 */
 TIM_InitStruct.Prescaler = 0;
 TIM_InitStruct.CounterMode = LL_TIM_COUNTERMODE_UP;
 TIM_InitStruct.Autoreload = 3999;
 TIM_InitStruct.ClockDivision = LL_TIM_CLOCKDIVISION_DIV1;
 TIM_InitStruct.RepetitionCounter = 0;
 LL_TIM_Init(TIM1, &TIM_InitStruct);
 LL_TIM_DisableARRPreload(TIM1);
 TIM_OC_InitStruct.OCMode = LL_TIM_OCMODE_FROZEN;
 TIM_OC_InitStruct.OCState = LL_TIM_OCSTATE_DISABLE;
 TIM_OC_InitStruct.OCNState = LL_TIM_OCSTATE_DISABLE;
 TIM_OC_InitStruct.CompareValue = 0;
 TIM_OC_InitStruct.OCPolarity = LL_TIM_OCPOLARITY_HIGH;
 TIM_OC_InitStruct.OCNPolarity = LL_TIM_OCPOLARITY_HIGH;
 TIM_OC_InitStruct.OCIdleState = LL_TIM_OCIDLESTATE_LOW;
 TIM_OC_InitStruct.OCNIdleState = LL_TIM_OCIDLESTATE_LOW;
 LL_TIM_OC_Init(TIM1, LL_TIM_CHANNEL_CH1, &TIM_OC_InitStruct);
 LL_TIM_OC_DisableFast(TIM1, LL_TIM_CHANNEL_CH1);
 LL_TIM_SetTriggerOutput(TIM1, LL_TIM_TRGO_RESET);
 LL_TIM_SetTriggerOutput2(TIM1, LL_TIM_TRGO2_RESET);
 LL_TIM_DisableMasterSlaveMode(TIM1);
 TIM_BDTRInitStruct.OSSRState = LL_TIM_OSSR_DISABLE;
 TIM_BDTRInitStruct.OSSIState = LL_TIM_OSSI_DISABLE;
 TIM_BDTRInitStruct.LockLevel = LL_TIM_LOCKLEVEL_OFF;
 TIM_BDTRInitStruct.DeadTime = 0;
 TIM_BDTRInitStruct.BreakState = LL_TIM_BREAK_DISABLE;
 TIM_BDTRInitStruct.BreakPolarity = LL_TIM_BREAK_POLARITY_HIGH;
 TIM_BDTRInitStruct.BreakFilter = LL_TIM_BREAK_FILTER_FDIV1;
 TIM_BDTRInitStruct.BreakAFMode = LL_TIM_BREAK_AFMODE_INPUT;
 TIM_BDTRInitStruct.Break2State = LL_TIM_BREAK2_DISABLE;
 TIM_BDTRInitStruct.Break2Polarity = LL_TIM_BREAK2_POLARITY_HIGH;
 TIM_BDTRInitStruct.Break2Filter = LL_TIM_BREAK2_FILTER_FDIV1;
 TIM_BDTRInitStruct.Break2AFMode = LL_TIM_BREAK_AFMODE_INPUT;
 TIM_BDTRInitStruct.AutomaticOutput = LL_TIM_AUTOMATICOUTPUT_DISABLE;
 LL_TIM_BDTR_Init(TIM1, &TIM_BDTRInitStruct);
 /* USER CODE BEGIN TIM1_Init 2 */
 /* USER CODE END TIM1_Init 2 */
/* TIM8 init function */
void MX_TIM8_Init(void)
 /* USER CODE BEGIN TIM8_Init 0 */
 /* USER CODE END TIM8_Init 0 */
 LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_TIM8);
 /* TIM8 interrupt Init */
 NVIC_SetPriority(TIM8_UP_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
 NVIC_EnableIRQ(TIM8_UP_IRQn);
 /* USER CODE BEGIN TIM8_Init 1 */
 /* USER CODE END TIM8_Init 1 */
 TIM_InitStruct.Autoreload = 19999;
 LL_TIM_Init(TIM8, &TIM_InitStruct);
 LL_TIM_DisableARRPreload(TIM8);
 LL_TIM_OC_Init(TIM8, LL_TIM_CHANNEL_CH1, &TIM_OC_InitStruct);
 LL_TIM_OC_DisableFast(TIM8, LL_TIM_CHANNEL_CH1);
 LL_TIM_SetTriggerOutput(TIM8, LL_TIM_TRGO_RESET);
 LL_TIM_SetTriggerOutput2(TIM8, LL_TIM_TRGO2_RESET);
 LL_TIM_DisableMasterSlaveMode(TIM8);
 LL_TIM_BDTR_Init(TIM8, &TIM_BDTRInitStruct);
 /* USER CODE BEGIN TIM8_Init 2 */
 /* USER CODE END TIM8_Init 2 */
stm32h5xx_it.c
/* USER CODE BEGIN PV */
volatile uint32_t TIM1Count = 0;
volatile uint32_t TIM8Count = 0;
volatile uint32_t TIMDiff = 0;
/* USER CODE END PV */
 * @brief This function handles TIM1 Update interrupt.
void TIM1_UP_IRQHandler(void)
 /* USER CODE BEGIN TIM1_UP_IRQn 0 */
	if (LL_TIM_IsActiveFlag_UPDATE(TIM1)) {
		LL_TIM_ClearFlag_UPDATE(TIM1);
		TIM1Count += 5;
 /* USER CODE END TIM1_UP_IRQn 0 */
 /* USER CODE BEGIN TIM1_UP_IRQn 1 */
 /* USER CODE END TIM1_UP_IRQn 1 */
 * @brief This function handles TIM8 Update interrupt.
void TIM8_UP_IRQHandler(void)
 /* USER CODE BEGIN TIM8_UP_IRQn 0 */
	if (LL_TIM_IsActiveFlag_UPDATE(TIM8)) {
		LL_TIM_ClearFlag_UPDATE(TIM8);
		TIM8Count++;
		TIMDiff = TIM1Count - TIM8Count; // <-- Diff increases
 /* USER CODE END TIM8_UP_IRQn 0 */
 /* USER CODE BEGIN TIM8_UP_IRQn 1 */
 /* USER CODE END TIM8_UP_IRQn 1 */
jhsonBest answer
Oct 29, 2025 12:54 AM UTC
There was a mistake when editing code snippet for upload.
Correct one would look like below as you suggested.
		TIM1Count++;
		TIM8Count += 5;
And the problem was that I was using TIM1 as center aligned mode 1 in the original code.
So using (Desired ARR - 1) as ARR for TIM1 was a critical mistake causing the drift.
Using (Desired ARR) as ARR for TIM1 and using (Desired ARR * 5 - 1) as ARR for TIM8 solved my problem.
Thank you!
Oct 28, 2025 1:16 PM UTC
Should work unless interrupts are getting blocked.
What does your main.c look like? What other interrupts are active in the system and what are their priorities?
waclawek.jan
Oct 28, 2025 3:14 PM UTC
You set TIM1's period to be 4000 clock periods and TIM8's period to be 20000 clock periods, so there are 5 TIM1 cycles in one TIM8 cycle; thus for one increment of TIM8Count, you increment TIM1Count by 5 * 5 = 25.
jhsonAuthorBest answer
		TIM1Count++;
		TIM8Count += 5;
Thank you!
waclawek.jan
Oct 29, 2025 8:25 AM UTC
Thanks for explanation, but
this is why it's better to copy/paste code unedited. Or, even better, post a minimal but complete compilable code exhibiting the problem.
Glad you got it working.
