mehmet.karakaya
Dec 29, 2010 10:30 PM UTC
timer hall sensor mode - why doesnot it function corectly?
Posted on December 29, 2010 at 23:30
    lowpowermcu
    May 17, 2011 12:19 PM UTC
    Posted on May 17, 2011 at 14:19
    Hi mehmet,
    I don't have a hall sensor so I am just reading the reference manual.
    Let's do it together (I am just enjoying using these timers):
    The reference manual says:
    - The “interfacing timer�? captures the 3 timer input pins connected through an
    XOR gate to the TI1 input channel (selected by setting the TI1S bit in the TIMx_CR2
    register
    ---> TIM2->CR2 |= 0x80;  // bit TI1S
    - The slave mode controller is configured in reset mode; the slave input is TI1F_ED.
    TIM2->SMCR |= 0x0004; //write the SMS bits to 100 in the TIMx_SMCR register to select reset mode
    TIM2->SMCR |= 0x0040;//TI1 Edge Detector (TI1F_ED); the slave input is TI1F_ED
    Then enable the commutation interrupt using DIER register
    TIM_ITConfig(TIM2, TIM_IT_COM, ENABLE);
    and in the IRQ try to toggle a GPIO pin (like GPIOC->ODR ^= GPIO_Pin_2;) to check that timer detects channels toggling.
    Tell me if it is OK now.
    MCU Lüfter
    mehmet.karakaya
    Hello  MCU Lüfter ,
    thank you for answer
    neither the manual nor the peripheral library doestnot show
    how the hall sensor mode is initialized
    and it is too complicated for me
    can you please give me a code example
    lowpowermcu
    Hi mehmet,
    ''The slave mode controller is configured in reset mode; the slave input is TI1F_ED.''
    but I can't find it in your code.
    Where is it done ?
    MCU Lüfter
    lowpowermcu
    Hi mehmet,
    Ah sorry,
    Just change ''TIM_ITConfig(TIM2, TIM_IT_COM, ENABLE);''
    by ''TIM_ITConfig(TIM2, TIM_IT_CC1, ENABLE);''
    BTW interfacing timer is the same as slave timer and it can be TIM2...
    TIM1 or TIM8 is the ''master'' timer who generates the PWM signal.
    Thanks to correct me if it doesn't match your understanding.
    I have another update :)
    in the capture configuration
    you should use   TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_TRC;
    and not TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
    that is what says the reference manual
    ''On the “interfacing timer�?, capture/compare channel 1 is configured in capture mode,
    capture signal is TRC''.
    CC1S to ''11'': CC1 channel is configured as input, IC1 is mapped on TRC.
    MCU Lüfter
    mehmet.karakaya
    hello MCU Lüfter ,
    in your example interfacing and slave timers are both timer2
    ( it confused me )
    I found another solution
    I look at the state of CH1 int the Timer ISR ( CC1 interrupt )
    and change CC1P: Capture/Compare 1 input polarity for the next interrupt
    void TIM2_IRQHandler(void){
        if(TIM_GetITStatus(TIM2, TIM_IT_CC1) == SET) {
            TIM_ClearFlag(TIM2, TIM_FLAG_CC1);
            TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
            if(GPIOA->IDR&GPIO_Pin_0) TIM2->CCER|=0x2;else TIM2->CCER&=~((int16_t)0x2);
        } and same for other 2 chanles CH2 and CH3
    now in above ISR I will software generate a COM interrupt for Timer 8 which is producing PWM signals conected to IGBT switches
    this way I will control my brushless DC motor - I hope so :)
    mehmet.karakaya
    hello ,
    connect hall sensor UVW to CH1 CH2 CH3 of a free timer
    try capturing rising falling edges of them
    ( if you captured a rising edge change the polarity of IC to falling for next interrupt and vice versa )
    and generate a software COM event for the PWMing timer
    in ST peripheral library there is an application ''6Steps'' under ''tim'' examples
    it shows how to disable and enable high and low order IGBTs
    in COM interrupt
    alexandernath9
    hi,
    has somebody of you a working code for interfacing the hall-sensors to control a bldc with pwm? i try to do this for about one month now and it will never work :(
    thanks a lot
    a. nath
    mehmet.karakaya
    hello
    this is my hallinit and timer 2 interrupt
    it works well but I only simulated the PWM outputs with LEDS
    I could see the TIM8 COM interrupt called by every change of hall sensors
    void Hallinit(void){
      TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
      TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
      TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
      TIM_ICInitStructure.TIM_ICFilter = 0x0;
      TIM_ICInit(TIM2, &TIM_ICInitStructure);
      TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
      TIM_ICInitStructure.TIM_Channel = TIM_Channel_3;
      if(GPIOA->IDR&GPIO_Pin_0) TIM2->CCER|=0x2;else TIM2->CCER&=~((uint16_t)0x2);
      if(GPIOA->IDR&GPIO_Pin_1) TIM2->CCER|=0x20;else TIM2->CCER&=~((uint16_t)0x20);
      if(GPIOA->IDR&GPIO_Pin_2) TIM2->CCER|=0x200;else TIM2->CCER&=~((uint16_t)0x200);
      TIM_Cmd(TIM2, ENABLE);
      TIM_ITConfig(TIM2, TIM_IT_CC1|TIM_IT_CC2|TIM_IT_CC3, ENABLE);
        if(TIM_GetITStatus(TIM2, TIM_IT_CC2) == SET) {
            TIM_ClearFlag(TIM2, TIM_FLAG_CC2);
            TIM_ClearITPendingBit(TIM2, TIM_IT_CC2);
            if(GPIOA->IDR&GPIO_Pin_1) TIM2->CCER|=0x20;else TIM2->CCER&=~((int16_t)0x20);
        if(TIM_GetITStatus(TIM2, TIM_IT_CC3) == SET) {
            TIM_ClearFlag(TIM2, TIM_FLAG_CC3);
            TIM_ClearITPendingBit(TIM2, TIM_IT_CC3);
            if(GPIOA->IDR&GPIO_Pin_2) TIM2->CCER|=0x200;else TIM2->CCER&=~((int16_t)0x200);
        TIM_GenerateEvent(TIM8, TIM_EventSource_COM);
    alexandernath9
    The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6Zg&d=%2Fa%2F0X0000000bqz%2F5SJj8lj6yvKX3F6kwdLKZrCOPAeBXPAV9isTYnlgta4&asPdf=false
