jveith
May 7, 2011 10:38 AM UTC
Timer External Clock
Posted on May 07, 2011 at 12:38
    jveith
    jveithAuthor
    May 17, 2011 12:34 PM UTC
    Posted on May 17, 2011 at 14:34
    > There must be a hardware bug
    The reason for not counting was a cold solder junction at the enameled copper wire what does the modification of PCB from T2-CH4 to T3_ETR pin. As soon as there is a signal with edges at the ETR pin, the above posted code increments the counter like expected.
    >no matter what I tried I couldnot count ETR pulses
    Try the code from above and check your ETR pin for present pulses. If they are missing, there must be a hardware bug...
    mehmet.karakaya
    dont waste your time trying to count ETR pulses
    try counting CH1 pulses instead
