Posted on May 17, 2011 at 14:00 Thks for the quick reply: You are right, I see it now. My question now is, what is the diference between external trigger and TI input? If both of them increases the counter by one in rising edge, won´t it be the same? Obviously not, but I don´t see why now? Thks
wey I think that I finally find it :) If you look at ''general block diagram'', you will find that ''TI1'' is connected to ''TIM CH1'' and so on for TI2 and TI3. Perhaps ''TI'' means ''Timer input''. I think that it is more clear now ! Regards, MCU Lüfter
