Timer change output compare mode to PWM
Posted on February 15, 2012 at 16:19
I want to use a a advanced control timer (TIM8) of my STM32F103ZG (on STM3210E-EVAL) for motor control. I have problems generating the PWM signal at the right time. I initialize the timer the same way as in the 6-step example out of the std. peripherals lib examples, i.e.: TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing; Later I try to start the PWM output mode with: TIM_SelectOCxM(TIM8, TIM_Channel_1, TIM_OCMode_PWM1); TIM_CCxCmd(TIM8, TIM_Channel_1, TIM_CCx_Enable); This has no effect. When I use TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; instead in the init phase, then PWM output works. I use an oscilloscope for verification. Thanks. best regards, sebastian
