mtaisser9
Apr 28, 2008 6:19 AM UTC
TIM4 do not work in STM32F103V8T6
Posted on April 28, 2008 at 08:19
    mtaisser9
    mtaisser9Author
    May 17, 2011 10:31 AM UTC
    Posted on May 17, 2011 at 12:31
    hy!
    i know, my fault, i copied the wrong part of my code.
    I tried to initialize all 4 timers.
    1 - 3 worked fine, only 4th doesn't work.
    I took a look at the registers of TIM4 with the debugger when this line appears
    Code:
    TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
    and nothing happens there.
    it looks like TIM4 isn't there!
    whole code is now:
    Code:
    // TIM4 clock enable 24MHz
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
    // Time base configuration
    TIM_TimeBaseStructure.TIM_Period = TIM4_Freq_16kHz;
    TIM_TimeBaseStructure.TIM_Prescaler = 1;
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_ITConfig(TIM4,TIM_IT_Update, ENABLE);
    // Enable TIM4 global Interrupt
    NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQChannel;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    // TIM enable counter
    TIM_Cmd(TIM4, ENABLE);
    smart
    Take a look at this line of your code
    NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQChannel;
    You have enabled the TIM3 interrupt not Timer 4
    This could be a problem....
    mtaisser9
    mtaisser9Author
    Hy!
    i try to use timer 4 (TIM4) in my project, but it doesn't work.
    Till now i tried all other timers (Timer1, Timer2&3) and they are working fine.
    I used the same initialization routines for Timer4 as for the others:
    Code:
    Timer 4 should be available in this device (described in the datasheet).
    µC: STM32F103V8
    IAR Embedded Workbench IDE
    JLINK for ARM processors
    Does anybody knows this issue or knows what happens with TIM4 in this device???
    mtaisser9
    mtaisser9Author
    i tried the example 8 with the ''GettingStarted'' workspace for IAR Workbench, and it works!
    i also checked the registers for TIM4 with debugger and the output pin channel1 of tim4.
    it worked fine.
    so i checked all my project settings, and did changes at the DEBUGGER -> DOWNLOAD -> Flash loader file.
    this was set to ''$TOOLKIT_DIR$\config\flashloader\ST\FlashSTM32F10x.d79'' manually.
    i changed it to the ''Default'' setting like in the working workspace (TIM4 example), and now i get crazy errors:
    Fri Apr 25 15:20:26 2008: DLL version: V3.80c, compiled Apr 9 2008 18:56:00
    Fri Apr 25 15:20:26 2008: Firmware: J-Link ARM V6 compiled Mar 3 2008 18:04:42
    Fri Apr 25 15:20:26 2008: JTAG speed is initially set to: 32 kHz
    Fri Apr 25 15:20:26 2008: TotalIRLen = 9, IRPrint = 0x0011
    Fri Apr 25 15:20:26 2008: Found Cortex-M3, Little endian.
    Fri Apr 25 15:20:26 2008: TPIU fitted.
    Fri Apr 25 15:20:26 2008: FPUnit: 6 code (BP) slots and 2 literal slots
    Fri Apr 25 15:20:26 2008: Hardware reset with strategy 1 was performed
    Fri Apr 25 15:20:26 2008: Initial reset was performed
    Fri Apr 25 15:20:26 2008: J-Link found 2 JTAG devices. ARM core Id: 3BA00477(Cortex M3), ARM core Id: 00000000(ARM9)
    Fri Apr 25 15:20:26 2008: Device at TAP0 selected
    Fri Apr 25 15:20:28 2008: 3518 bytes downloaded and verified (2.36 Kbytes/sec)
    Fri Apr 25 15:20:28 2008: Warning:
    Verify error at address 0x20000168, target byte: 0x00, byte in file: 0x09
    Verify error at address 0x20000169, target byte: 0x00, byte in file: 0x68
    Verify error at address 0x2000016A, target byte: 0x00, byte in file: 0x51
    Verify error at address 0x2000016B, target byte: 0x00, byte in file: 0xF0
    Verify error at address 0x2000016C, target byte: 0xBE, byte in file: 0x04
    Verify error at address 0x2000016D, target byte: 0x0A, byte in file: 0x01
    Verify error at address 0x2000016E, target byte: 0x00, byte in file: 0x01
    Verify error at address 0x2000016F, target byte: 0x00, byte in file: 0x60
    Verify error at address 0x20000170, target byte: 0x32, byte in file: 0x06
    Verify error at address 0x20000171, target byte: 0x0C, byte in file: 0x48
    Verify error at address 0x20000172, target byte: 0x00, byte in file: 0x06
    Verify error at address 0x20000173, target byte: 0x00, byte in file: 0x49
    Verify error at address 0x20000174, target byte: 0x04, byte in file: 0x09
    Verify error at address 0x20000175, target byte: 0x0A, byte in file: 0x68
    Verify error at address 0x20000176, target byte: 0x00, byte in file: 0x01
    Verify error at address 0x20000177, target byte: 0x00, byte in file: 0x22
    Verify error at address 0x20000178, target byte: 0xD6, byte in file: 0x91
    Verify error at address 0x20000179, target byte: 0x02, byte in file: 0x43
    Verify error at address 0x2000017A, target byte: 0x00, byte in file: 0x01
    Verify error at address 0x2000017B, target byte: 0x00, byte in file: 0x60
    Verify error at address 0x2000017C, target byte: 0x1F, byte in file: 0x24
    Verify error at address 0x2000017D, target byte: 0x0F, byte in file: 0x1D
    Verify error at address 0x2000017E, target byte: 0x00, byte in file: 0x3F
    Verify error at address 0x2000017F, target byte: 0x00, byte in file: 0x1D
    Fri Apr 25 15:20:28 2008: There were warnings during download of FLASH loader, see Log Window
    Fri Apr 25 15:20:29 2008: Failed to load flash loader: C:\Programme\IAR Systems\Embedded Workbench 4.0 Kickstart\arm\config\flashloader\ST\FlashSTM32F10x.d79
    When i try to change to the settings before, the same error occurs.
    i don't know what to do now.
    i tried 2 boards with my described processor type, and the IAR kickstart kit board, nothing helps!!!
    jilisegiar
    can you try the TIM example 8 from the ''ARM-based 32-bit MCU STM32F101xx and STM32F103xx firmware library''. It uses the TIM4 and it works fine.
    http://www.st.com/mcu/modules.php?name=mcu&file=familiesdocs&FAM=110#Firmware
    mtaisser9
    mtaisser9Author
    Hy!
    Today i did some other tests with my software.
    i took another (unflashed) board, and tried my software without enabling the ADC with DMA.
    the flashing and debugging with ''IAR workbench'' worked fine!
    i repeated that procedure several times without any problem.
    Than i tried to enable the ADC with DMA.
    The first programming (flashing) was done correctly and all works fine.
    but when i try to flash again the same software the described errors appear.
    What could be the problem???
    my ADC init routine:
    Code:
    void Analog_Init(void)
    // Enable DMA clock
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA, ENABLE);
    // Enable ADC1 and GPIOC clock
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC, ENABLE);
    // DMA channel1 configuration ----------------------------------------------
    DMA_DeInit(DMA_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_ConvertedValueTab;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize = 6;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA_Channel1, &DMA_InitStructure);
    // Enable DMA Channel1
    DMA_Cmd(DMA_Channel1, ENABLE);
    // ADC1 configuration ------------------------------------------------------
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = 6;
    ADC_Init(ADC1, &ADC_InitStructure);
    // ADC1 regular channels configuration
    ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 3, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 4, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 5, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 6, ADC_SampleTime_239Cycles5);
    // Enable ADC1 DMA
    ADC_DMACmd(ADC1, ENABLE);
    // Enable ADC1
    ADC_Cmd(ADC1, ENABLE);
    // Enable ADC1 reset calibaration register
    ADC_ResetCalibration(ADC1);
    // Check the end of ADC1 reset calibration register
    while(ADC_GetResetCalibrationStatus(ADC1));
    // Start ADC1 calibaration
    ADC_StartCalibration(ADC1);
    // Check the end of ADC1 calibration
    while(ADC_GetCalibrationStatus(ADC1));
    // Start ADC1 Software Conversion
    ADC_SoftwareStartConvCmd(ADC1, ENABLE);
    mtaisser9
    mtaisser9Author
    hy!
    in principle its the same code like in the ''getting started'' example, only with the Example 8 files included.
    with my company project i started also with the ''gettingStarted''.
    Following peripherals are in use:
    ADC with DMA
    I2C for Display
    I2C for Flash
    TIM1 to 3
    and some GPIO for keyboard etc.
    i recognized the first problems since i included the ADC with DMA!
    i don't know if this could be the problem
    jilisegiar
    Can you share your project
    mtaisser9
    mtaisser9Author
    Thanks, but it didn't work with this settings, because they are already set.
    i tried the ''software reset'' and it works!
    is it ok to set to ''software reset''?
    jilisegiar
    To avoid this problem try to reconfigure your project as in the attached image
