w21685
TIM3 Clock output control
  • October 4, 2016
  • 676 views
Posted on October 04, 2016 at 21:21
I'd like to know how to enable or disable freely for TIM3 clock output after initialization.
Once clock output is enabled, I cannot disable the clock ouput.
Device: STM32F207ZG
Thanks.
#timer-clock-enable-disable
waclawek.jan
Posted on October 04, 2016 at 22:14
Assuming you output PWM through one of the timer's compare channel and you want to tristate the related pin, you have several options:
- change the pin's mode from AF to Input, in GPIO
- disable output compare through respective TIMx_CCER.CCyE (this is probably what you really want)
- change the given channel's mode from Compare to Capture, TIMx_CCMRz.CCyS = 0b01 (changing this requires to switch the channel off using CCyE anyway, so this is not really an option)
w21685
w21685Author
Posted on October 07, 2016 at 16:27
Thank you very much for your relpy!
I solved it thanks to your help.
