hs.low9
TIM_OCMode? which one to use?
Posted on June 16, 2008 at 12:43
    hs.low9
    hs.low9Author
    hs.low9
    hs.low9Author
    Posted on May 17, 2011 at 12:37
    hi,
    I am newbie trying with STM32 timer.
    Can any one explain or tell me where can i find information on the different between following timer mode?
    Table 476. TIM_OCMode definition
    TIM_OCMode_Timing: TIM Output Compare Timing mode.
    TIM_OCMode_Active: TIM Output Compare Active mode.
    TIM_OCMode_Inactive: TIM Output Compare Inactive mode.
    TIM_OCMode_Toggle: TIM Output Compare Toggle mode.
    TIM_OCMode_PWM1: TIM Pulse Width Modulation mode1.
    TIM_OCMode_PWM2: TIM Pulse Width Modulation mode2.
    Many Thanks
